close button in the upper right menu - inoperative since update version 11 of Firefox on iPhone iOS ?
Re : close button in the upper right menu - inoperative since the recent update to version 11 of Firefox on iPhone iOS ?
Hello,
I have originally posted on the French language about that issue : https://forums.mozfr.org/viewtopic.php?f=5&t=137633
and now I am also posting here.
In the menu "...", I have a choice "Close" (in French : Fermer, in Spanish : Cerrar), but it is doing nothing since the last update...
It is the last choice in blue letters. It just does not work.
It used to work with the past version.
(I do not want to use the workaround to manage the closing of tabs by the down bar menu... I would just like to have the blue menu to work properly.)
Yours sincerely,
所有回覆 (2)
The GUI looks akward to me, absolutely strange.
The only solution is to go through the Tabs menu in the bottom of the screen...
In my opinion, the Close menu just close the menu window, not the navigator window...
Someone has adviced me to open a feature request on Bugzilla :
